| Product(s): | OpenPlant Isometrics Manager |
| Version(s): | 08.11.09.XXX (SS5) |
| Environment: | Windows 7/8.1 (64 bit) |
| Area: | Errors-Logs-Messages |
| Subarea: | Open/Save |
| Original Author: | Dinesh Solanki, Bentley Product Advantage Group |
Error: XCHG0000: Invalid Translation Format: OPIM
One of the project gives this error when trying to Initialize OpenPlant Isometrics Manager from inside AutoPLANT Modeler.
The syspref.ini may be missing a section or project may reference a different syspref.ini than the default syspref.ini. Please check below suggestion to resolve this issue.
Default Location
Find the syspref.ini file in use for the project
If above problem still persist, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
