| Applies To& | |
| Product(s): | OpenPlant Isometrics Manager |
| Version(s): | 08.11.09.XXX (SS5) | 08.11.11.XXX (SS6) |
| Environment: | Windows 7/8.1/10 (64 bit) |
| Area: | Open/Save |
| Subarea: | - |
| Original Author: | Harpreet Singh, Bentley Product Advantage Group |
By default, workspace root points to the default location of OpenPlant Modeler workspace which is C:\ProgramData\Bentley\OpenPlantModeler V8i\WorkSpace. However if modeler workspace is on shared location then OpenPlant Isometrics Manager does not read the shared location. This article will explain the steps required to read the shared workspace.
communities.bentley.com/.../how-to-save-isometrics-output-on-network-drive
