| Product(s): | OpenPlant Modeler | ||
| Version(s): | 08.11.09.XXX | ||
| Environment: | Windows 7 (64 bit) | ||
| Area: | OpenPlant Specification Generator | ||
| Subarea: | Custom Description | ||
| Original Author: | Deepak Singh, Bentley Product Advantage Group |
In Specification Generator, user wants to define, modify static text of Custom Description field.
While modifying defined static text of custom description, editing occurs outside the braces of static text. Refer below steps to define,modify the static text. This article explains about addition & modification of custom description for pipe.
b. To Modify Static Text
Defined static text can be modified by adding “<<>>” after the defined static text.
E.g. to modify <<CATALOG>><<COMP_LEN>>[ASME B 31.8] as <<CATALOG>><<COMP_LEN>>[ASME B 31.8 PIPE], enter <<>> first & try to modify the defined static text as shown below.
Once static text has been modified as desired you can delete <<>>. Save the description & verify the result as shown.
