| Version(s): | V8i (08.11.09.829) | ||
| Environment: | Architectural Design | ||
| Area: | N/A | ||
| Subarea: | N/A |
While using the new Place Profile tool, it seems that sometimes when profiles are joined to a corner using the Join at L command, the profile is no longer broken at any door/windows it crosses. It’s as though the door’s sense distance is too small to reach through the profile. The parameters that seem to cause this are:
This issue occurs because connecting the profiles disassociates them from the wall; remember that placing a profile using the “By Path” option is meant to assist in placement, not act as a constraint-creation tool. In order to resolve the issue simply increase the door or window’s Sense Distance value.
