How To Label Valve Tags-v8i
 Product(s): OpenPlant Isometrics Manager
 Version(s):08.11.09.XXX
 Environment: Windows 7 64 bit & Others
 Area: Settings/Attributes
 Subarea:
 Original Author:Rahul Kumar, Bentley Technical Support Group
To Label valve Tag in OpenPlant Isometrics Manager.
Requirement is to label Valve tag to get appear in isometrics. Below steps describes how to label the valve tag under User label option provided to user to customize it as per their requirement.
  1. Launch OpenPlant Isometrics Manager. Click on configuration button. See image below.
  2. Under ‘User Label’ tag Enter the data with steps 1,2,3, as shown in image below. Assign all the value of component attribute. Selection of the expression IE_TYPE should be done carefully to get it appear in isometrics. This can be checked and confirmed from the component tag list shown in this step later.
  3. Click ‘Save’ and generate the isometric, the IE_TAG value will get displayed. See image below. (IE_TAG attribute value has been taken for reference).
  4. User can also set the other component attribute value in User label dialog as per requirement. To get the component attribute information see image below for reference.
communities.bentley.com/.../12641.modifying-the-iso-content
Comments or Corrections?
Bentley's Technical Support Group requests that you please confine any comments you have on this Wiki entry to this Comments or Corrections?" section. THANK YOU!
