How to Display Eccentric Reducer Offset Label in OpenPlant Isometrics Manager-v8i
Product(s):OpenPlant Isometrics Manager
Version(s):08.11.11.87 (SS6)
Environment:Windows 7/8.1/10 (64 bit)
Area:Settings/Attributes
Subarea:-
Original Author:Rahul Kumar, Bentley Product Advantage Group
To label Eccentric reducer offset values in Isometrics drawing.
In OpenPlant Isometrics Manager, for eccentric reducer there is no offset details by default. See image below after producing isometrics with default setup.
However, as per requirement user may add labels to display it in isometric drawing.
OpenPlant Modeler-OpenPlant Isometrics Manager
  1. Launch OpenPlant Isometrics Manager.
  2. Select Project unit, say OPModeler_Metric here and click OK.
  3. From Isometric configuration dialog, select “User Labels” node.
  4. Add new Label, and enter value as shown in below image.
    For Imperial Unit
    Name ECCENTRIC OFFSET
    Include EC_CLASS=ECCENTRIC_PIPE_REDUCER
    Text $(DIM1:I) Offset
    Type PLANTC
    Cell Name PLANTC
    For Metric Unit
    Text $(DIM1:.0f) Offset
    Type PLANTC
    Cell Name PLANTC
  5. Save Settings.
  6. Launch OpenPlant Isometrics Manager and verify results.
    For Imperial Unit
    For Metric Unit
AutoPLANT Modeler-OpenPlant Isometrics Manager
  1. Open "Isometric configuration" through Project Administrator.
  2. Select Settings option and click on "Create/Modify" option.
  3. In Isometric Configuration window select the desired Style.
    For Imperial Unit
    Type PLANTC
    Cell Name PLANTC
    For Metric Unit
    Type PLANTC
    Cell Name PLANTC
  5. Save Settings.
    For Imperial Unit
    For Metric Unit
communities.bentley.com/.../12641.modifying-the-isometric-content
Comments or Corrections?
