Cadworx object enabler for AECOsim Building Designer
 Version(s):08.11.09.866
 Environment:N\A
 Area:Import/Export
 Subarea:Other
Is there a Cadworks Object Enabler available for AECOSIM Building Designer?  We can open a Cadworks file, but all native objects displa as wireframe without any attributes.
No, it seems that Intergraph does not currently provide a Cadworx object enabler for MicroStation based applications such as AECOsim Building Designer.  The current list of object enablers is located here: http://www.coade.com/All-Product-Downloads.shtml
They also include a PDF charting the various model formats supported and how to use them in other applications: http://www.intergraph.com/assets/pdf/SPIOP_2015R1_3DModelFormatsandFiles.pdf   For CADWorx 2015 to MicroStation (or AECOsim) they suggest .dwg or .drv (design review), with at least RealDWG 2013 installed (included with SELECTseries5 or greater).
http://communities.bentley.com/products/interoperability/f/19567/p/111150/339345
 Original Author:Steve Cocchi
