| Product(s): | AECOsim Building Designer | |
| Version(s): | 08.11.09.863 | |
| Environment: | N\A | |
| Area: | Drawing Views | |
| Subarea: | Callouts | |
Problem Description
How to create Interior Drawing Views elevations?
Steps to Resolve
From the Place Callout tool, select "Place Elevation Callout" then toggle the option for "Interior Elevation" once selected make sure the seed for interior elevation is also selected.
Place drawing identifier in the room or area to point on each direction where an interior elevation will be created, once done with the selections "accept" (right click) , hit OK to finish and create the elevations.
