| Product(s): | OpenPlant Isometrics Manager |
| Version(s): | 08.11.09.404 & above |
| Environment: | Windows 7 64 bit & Others |
| Area: | Settings/Attributes |
| Subarea: | - |
| Original Author: | Abhijit Bute, Bentley Product Advantage Group |
To Modify Stub end length in OpenPlant Isometrics Manager.
In OpenPlant Isometrics Manager, User may have requirement to show stub end length bigger from the existing result. So that all dimension should be readable.
communities.bentley.com/.../12647.modifying-symbols-in-openplant-isometrics-manager
Comments or Corrections?
