| Product(s) | OpenPlant Isometrics Manager |
| Version(s) | 08.11.11.224(SS6) |
| Environment | Windows 7/8.1/10 64-bit |
| Area | Settings/Attributes |
| Subarea | |
| Original Author | Swapnil Joshi, Bentley Product Advantage Group |
To modify existing symbols in OpenPlant Isometrics Manager
The user wants to modify specific segment of an OpenPlant Isometrics Manager cell. In this case we shall modify a segment of a changeover valve.The changeover valve contains 5 segments, and we want to increase only one inlet segment of the cell. The current length of the inlet is 5 units.
communities.bentley.com/.../12647.modifying-symbols-in-openplant-isometrics-manager
If there is still some problem with modifying cells then please create a Service Request and contact Bentley Product Advantage group along with the list of all relevant details to get in depth analysis and for possible solution or workarounds.
