| Version(s): | 08.11.09.866 | ||
| Area: | Import/Export | ||
| Subarea: | Other |
Is there a MagiCAD Object Enabler available for AECOsim Building Designer? We can open a MagiCAD file, but all native objects display as wireframe / distorted without any attributes.
No, it seems that MagiCAD does not currently provide a MagiCAD object enabler for MicroStation based applications such as AECOsim Building Designer. The current list of object enablers is located here: https://portal.magicad.com/Download/GetProductCategoryList?categoryId=6
