Installation/Upgradation Steps for OpenPlant Isometrics Manager-v8i
Product(s): OpenPlant Isometrics Manager
Version(s): 08.11.09.XXX(SS5) | 08.11.11.87/103 (SS6)
Area: Open/Save
Subarea: Installation
Original Author: Abhijit Bute, Bentley Product Advantage Group
OpenPlant Isometrics Manager installation can be done for both OpenPlant Modeler and AutoPLANT Modeler. During the installation user need to select the correct option provided for each product. Following are the steps for installation for both application, OpenPlant Modeler - OpenPlant Isometrics Manager & AutoPLANT Modeler-OpenPlant Isometrics Manager.
After installation of OpenPlant Modeler, Run OpenPlant Isometrics Manager exe. See step by step procedure.
Note - Check OFF AutoPLANT Database Mode option when installing it for OpenPlant Modeler side.
Click on Finish and OpenPlant Isometrics Manager is ready to use along with OpenPlant Modeler.
AutoPLANT Modeler - OpenPlant Isometrics Manager
Case 1: To install a new version of OpenPlant Isometrics Manager.
After installation of AutoPLANT Modeler, Run OpenPlant IsometricsManager exe. See step by step procedure
Note - Check OFF OpenPlant ModelServer Mode option when installing it for AutoPLANT Modeler side.
Click on Finish and OpenPlant Isometrics Manager is ready to use along with AutoPLANT Modeler.
Case 2: To upgrade an existing version of OpenPlant Isometrics Manager
Background:
When a version of OpenPlant Isometrics Manager exists on the user machine and he wants to upgrade it to the latest version then he needs to follow the below mentioned steps.
  1. From the Control Panel open Programs and Features.
  2. Confirm the version of OpenPlant Isometrics Manager.
  3. Select the OpenPlant Isometrics Manager and click on Uninstall.
  4. Now to install the latest version of OpenPlant Isometrics Manager follow the steps mentioned above.
communities.bentley.com/.../17149.opensave-openplant-isometrics-manager
Comments or Corrections?
