| Version(s): | 10.0.0.154 | ||
| Area: | General | ||
| Subarea: | N/A |
The following features are no longer available and/or have been superseded in the AECOsim Building Designer Connect Edition:
| Feature | Description | Deprecated Key-ins |
| Drawing Extraction Manager (DEM) |
Deprecated
| Structural Documentation Center (SDC) |
Deprecated
| SpacePlanner |
Deprecated
Note: Retained Space Planning; Thematic Maps; Labeling |
| Viewsets & Non-Platform View Controls | Previously, AECOsim Building Designer View Display tools. Deprecated viewset.ma (loaded on-demand) in favor of Platform Displaysets. Retired Associated key-ins and dialogs. |
| Project Explorer Assistant | Removed from the Preferences dialog (Building Designer Category > Project Explorer Assistant > Turn On Link Assistant) | N/A |
| Dataset_GB | Dataset_GB permanently replaced with Dataset UK | N/A |
| Legacy items | Deprecated Legacy toolboxes; Legacy Grid tool; Legacy Terrain tool | N/A |
| Plant Utilities |
Retired hs-tools.ma (loaded on-demand). Retired STF_PLANTUTILS_CONFIG=$(TF_DATASETS)$(TF_DATASETNAME)\data\plantutils.ini (settings file for the Plant Utilities tools). Retired HS_CONFIG settings file for the Plant Utilities tools. Only evaluated if STF_PLANTUTILS_CONFIG variable is not set. | N/A |
| Catalog Upgrade Utility | Deprecated Update Catalog Files; Verify Architectural Instance Information
Previously made schema/catalog changes to assist the transition from legacy layer application to AECOsim Building Designer (upgraded DGN's created in versions previous to 2004). |
| Dataset Upgrade Utility | Deprecated Dataset Upgrade Utility; Dataset Upgrade Utility Settings
Previously made dataset changes to assist the transition from legacy layer application to AECOsim Building Designer. |
| Part Rendering Upgrade Utility | Deprecated Part Rendering Upgrade Utility
Legacy feature. Previously, used to scan all part files in the active workspace for part rendering definitions using palette files (*.pal), upgraded part rendering definitions from using *.pal files to *.dgnlib files compatible with Luxology. |
| Space Part Upgrade Utility | Deprecated Space Part Upgrade Utility
Previously used to upgrade legacy DataGroup catalog files for spaces with the part and family (defined ObjectMaterial property). |
| RAM 3D Viewer | Discontinued delivery of RAM 3D Viewer. | N/A |
| RAM Structural System Import/Export | Deprecate direct import/export from/to RAM Structural System, in favor of ISM | N/A |
| IFC2 | Dropped IFC2 ( IFC 2x3 and IFC4 remain) | N/A |
| Load/Unload of Discipline Specific Entry Points | Deprecate Load/Unload AECOsim Building Designer Applications |
Note: Load/Unload Electrical Application tools are replaced on the ribbon. (Key-ins: BUILDINGDESIGNER ENABLE ELECTRICAL;RIBBON REBUILD and BUILDINGDESIGNER DISABLE ELECTRICAL;RIBBON REBUILD)
| Duplicate Solar Utilities | Deprecated Solar Shade; Solar Study |
| Electrical integration with Visual | Support for Electrical integration with Visual is no longer available in the AECOsim Building Designer CONNECT Edition. Visual no longer supports 3rd party integration for their recent versions. | |
| Place RFA as Cell | Places an RFA directly into your file. Replaced by the MicroStation Import RFA command |
