| Version(s): | 08.11.09.866 | ||
| Area: | Installation | ||
| Subarea: | N\A |
The following Optional Parameters can be set for a customized silent installation for AECOsim Building Designer in conjunction with the standard Windows ® Installer command line options (msiexec /Option <Required Parameter> [Optional Parameter]). These parameters allow you to set the location of the program installation directory, the location of your workspaces and set the backup state of existing datasets.
Parameter Name |
Description |
APPLICATIONFOLDER |
The directory where the AECOsim Building Designer program and associated files will be installed. If not defined, the installer will use the default program location. This value must be quoted if it contains spaces or other characters that are reserved by the command shell. |
PACKAGE_HOMEROOT |
The directory where the AECOsim Building Designer workspaces and associated files will be installed. If not defined, the installer will use the default Workspace location. This value must be quoted if it contains spaces or other characters that are reserved by the command shell. |
BACKUPDATASET |
If set to '=0' or undefined, the prompt from AECOsim Building Designer to "Backup the dataset" is suppressed and the dataset is NOT backed up (default behavior for silent installs). If set to ‘=1’, the prompt from AECOsim Building Designer to "Backup the dataset" is suppressed and the dataset is automatically backed up. |
For example:
msiexec /i "AECOsimBuildingDesigner.msi" APPLICATIONFOLDER="C:\Silent Install\Program\" PACKAGE_HOMEROOT="C:\Silent Install\HomeRoot\" BACKUPDATASET=0 /qn /l*v c:\silent.log.
This example performs a silent install of AECOsim Building Designer in quiet mode w/ no UI (/qn) , placing the program files under C:\Silent Install\Program\ (APPLICATIONFOLDER="C:\Silent Install\Program\") and the workspace under C:\Silent Install\HomeRoot\ (PACKAGE_HOMEROOT="C:\Silent Install\HomeRoot\"). The dataset is backup prompt is suppressed and is defined Not to be backed up (BACKUPDATASET=0) and the entire installation process is logged to a file located at C:\silent.log (/l*v c:\silent.log)
Other examples:
Silent install with defaults:
msiexec /i "AECOsimBuildingDesigner.msi" /qn /l*v c:\silent.log
Silent install with redirection of folder locations:
msiexec /i "AECOsimBuildingDesigner.msi" APPLICATIONFOLDER="E:\Program Files (x86)\Bentley\AECOsimBuildingDesigner V8i Ss6\" PACKAGE_HOMEROOT="E:\ProgramData\Bentley\AECOsimBuildingDesigner V8i Ss6\" /qn /l*v c:\silent.log
Silent uninstall using SS6 Product Code (use this if the original .msi that the install was carried out form is no longer present on the machine(s) concerned), backing up dataset:
msiexec /uninstall {8F545017-6809-4342-81D1-77E4346A2841} /qn BACKUPDATASET=1
Note: the Product Code for Ss6 can be found in the registry under :
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Bentley\AECOsimBuildingDesigner\{8F545017-6809-4342-81D1-77E4346A2841}
The SS5 Product Code is: {D9E22B89-638A-4665-9ACC-7A8C86FDD71D}
A full description of msiexec and its required and optional parameters can displayed by entering msiexec /help in the command window.
The same commands can be used for the datasets:
Typical Dataset Silent Install:
msiexec /i "C:\BentleyDownloads\dataset_ANZInstaller.msi" /qn /passive BACKUPDATASET=0 BDMINVERSION=08.11.09.800
Typical Dataset Silent Uninstall:
msiexec /uninstall "C:\BentleyDownloads\dataset_ANZInstaller.msi" /qn /passive BACKUPDATASET=0
This is standard Windows ® Installer technology (V 5.0.7601.17514), the folowing options are available if needed, more information about these is available on microsoft.com.
</package | /i> <Product.msi>
Installs or configures a product
/a <Product.msi>
Administrative install - Installs a product on the network
/j<u|m> <Product.msi> [/t <Transform List>] [/g <Language ID>]
Advertises a product - m to all users, u to current user
</uninstall | /x> <Product.msi | ProductCode>
Uninstalls the product
/quiet
Quiet mode, no user interaction
/passive
Unattended mode - progress bar only
/q[n|b|r|f]
Sets user interface level
n - No UI
b - Basic UI
r - Reduced UI
f - Full UI (default)
/help
Help information
/norestart
Do not restart after the installation is complete
/promptrestart
Prompts the user for restart if necessary
/forcerestart
Always restart the computer after installation
/l[i|w|e|a|r|u|c|m|o|p|v|x|+|!|*] <LogFile>
i - Status messages
w - Nonfatal warnings
e - All error messages
a - Start up of actions
r - Action-specific records
u - User requests
c - Initial UI parameters
m - Out-of-memory or fatal exit information
o - Out-of-disk-space messages
p - Terminal properties
v - Verbose output
x - Extra debugging information
+ - Append to existing log file
! - Flush each line to the log
* - Log all information, except for v and x options
/log <LogFile>
Equivalent of /l* <LogFile>
/update <Update1.msp>[;Update2.msp]
Applies update(s)
/uninstall <PatchCodeGuid>[;Update2.msp] /package <Product.msi | ProductCode>
Remove update(s) for a product
/f[p|e|c|m|s|o|d|a|u|v] <Product.msi | ProductCode>
Repairs a product
p - only if file is missing
o - if file is missing or an older version is installed (default)
e - if file is missing or an equal or older version is installed
d - if file is missing or a different version is installed
c - if file is missing or checksum does not match the calculated value
a - forces all files to be reinstalled
u - all required user-specific registry entries (default)
m - all required computer-specific registry entries (default)
s - all existing shortcuts (default)
v - runs from source and recaches local package
[PROPERTY=PropertyValue]
Consult the Windows ® Installer SDK for additional documentation on the command line syntax.
Copyright © Microsoft Corporation. All rights reserved.
Portions of this software are based in part on the work of the Independent JPEG Group.
Silent Install of AECOsim Building Designer
Enabling Silent Removal of Datasets - AECOsim Building Designer
| Original Author: | Marc Thomas |
