| Version(s): | CONNECT Edition (10.0.0.154) | ||
| Area: | Drawing Views | ||
| Subarea: | N/A |
Have there been any improvements in maintaining the synchronization between 3D Models and Drawing Views while using Cached views for better performance?
Yes, AECOsim Building Designer CONNECT Edition includes new "Cache Synch" settings that help to maintain incremental updates made within the 3D Model while using Cached mode for improved performance. These settings are available from both the Ribbon Bar and the References dialog box.
Manual: The cache is regenerated only when you manually reload the cached reference by either selecting the reload icon from the References dialog or by using the key in REFERENCE CACHED SYNCHRONIZE.
Key-in: REFERENCE VISIBLEEDGES CVESYNCH MANUAL
Automatic With Alert: On file open, displays an alert window mentioning that the cached visible display is out of date and whether you want to synchronize the display now. Select Yes to regenerate the cache.
Key-in: REFERENCE VISIBLEEDGES CVESYNCH AUTOMATIC
Automatic: The cache is automatically updated on file open. If you make changes to a reference when the file is open, the reload icon displays in the Status column. Clicking the icon reloads the cache.
Key-in: REFERENCE VISIBLEEDGES CVESYNCH ALERT
Disconnected: Retains the cache in its state. This allows very fast file opening.
Key-in: REFERENCE VISIBLEEDGES CVESYNCH DISCONNECTED
