| Version(s): | 10.00.00.154 | ||
| Area: | Installation | ||
| Subarea: | N/A |
If you participated in any of the pre-release CONNECT programs, in which you installed a Technology Preview or Release Candidate, it is critical that you completely uninstall those pre-release versions and its associated components prior to installing the commercial release version of AECOsim Building Designer CONNECT Edition (10.00.00.154).
After the reboot, you should be ready for a standard installation of AECOsim Building Designer CONNECT Edition (10.00.00.154).
