| Version(s): | 08.11.09.863 | ||
| Area: | Print/Plot | ||
| Subarea: | N\A |
How can I prevent certain elements in a drawing view model from printing? These elements can be on different levels, but I do not want to turn the whole level off since other elements are needed to display.
In a Drawing View, if you do not want to display certain elements, you can select all the elements that you DO want to display and right click to select "Isolate" in the pop up menu. This will turn the display of all other elements off and they will not be seen in the Print Preview and will not print.
