How to Control Socket Weld Symbols in OpenPlant Isometrics Manager-v8i
Product(s):OpenPlant Isometrics Manager
Version(s):08.11.11.XXX (SS5) | 08.11.11.XXX (SS6)
Area: Settings/Attributes
Subarea: Customization
Original Author:Dinesh Solanki, Bentley Product Advantage Group
In Plant Design, few users avoid showing Socket Weld graphically in the Isometrics, which means other weld symbol like Butt weld will be shown. To achieve this requirement minor change in Schema is required. The steps are applicable to both AutoPLANT Modeler and OpenPlant Modeler with OpenPlant Isometrics Manager. Below steps are described in context with both AutoPLANT Modeler-OpenPlant isometrics Manager & OpenPlant Modeler - OpenPlant Isometrics Manager.
Image Showing Socket Weld before modification.
OpenPlant Modeler-OpenPlant Isometrics Manager
  1. Using Bentley Class editor open "OpenPlant_3D.01.07.ecschema" schema and supplement it with "OpenPlant_3D_Supplemental_Isometrics_Isoextractor.01.07.ecschema" & "OpenPlant_3D_Supplemental_Modeling.01.07.ecschema".
    For More information on supplementing schema click here>>>>
  2. Using "Find Class" button search class "PIPING_FASTNER_SOCKET_WELD".
  3. For PIPING_FASTENER_SOCKET_WELD class, scroll down to Isometric Mappings custom attribute & change "Is Skip" from False to True as shown below.
  4. Navigate to JOINT class, go to Joint Type[2] for Joint Name SOCKET_WELD_JOINT.
  5. In Fastener field, replace WELD name to  "PIPING_FASTNER_SOCKET_WELD". See image below.
    Fastner[0]:  PIPING_FASTNER_SOCKET_WELD
  6. Save & Close Schema.
  7. Launch OpenPlant Isometrics Manager.
  8. Generate Isometrics & Verify Results. See image below.
AutoPLANT Modeler - OpenPlant Isometrics Manager
  1. Using Bentley Class editor open "OpenPlant_3D.01.07.ecschema" schema and supplement it with "OpenPlant_3D_Supplemental_Isometrics_Isoextractor.01.07.ecschema". See Default path mentioned below for Imperial project:
    C:\ProgramData\Bentley\Plant V8i\Bentley Plant V8i Projects\SAMPLE_IMPERIAL\Config\OpenPlant\schemas
  4. Save & Close Schema.
  5. Generate Isometrics & verify results.
  6. Socket welds will not be shown in the Isometrics see below image.
communities.bentley.com/.../24621.how-to-assign-fieldfit-weld-allowances-or-other-weld-types-for-bom-cut-list-in-openplant-isometrics-manager
Comments or Corrections?
