Connectivity Information Lost in Isometric After Detaching/Attaching Reference Model-v8i
 Product(s):OpenPlant Modeler
 Version(s):08.11.11.87(SS6)
 Environment: Windows 7 (64 bit)
 Area: Isometrics
 Subarea: Settings
 Original Author:Deepak Singh, Bentley Product Advantage Group
To show connectivity information in isometric generated after detaching and attaching reference model.
Problem Description
In OpenPlant Modeler, user has generated an isometric for a model having referenced model, but when user detach the referenced model attach again and generates isometric connectivity information is lost.
Steps to Resolve
  1. Go to project pcf file:
    C:\ProgramData\Bentley\OpenPlantModeler V8i\WorkSpace\Projects
  2. Right click on project .pcf file and select edit.
  3. Find the variable “OPM_PIPELINEMANAGER_INCLUDE_REFERENCED” by default it is set to false change it to True
  4. Save and close pcf file.
  5. Restart OpenPlant Modeler.
  6. Detach the referenced model, attach again notice the message in the status bar
  7. Generate isometric and verify result as shown below.
Still a Problem?
If above problem still persist, then please create a Service Request and contact the Bentley Product Advantage group.  Please include a list of all relevant details to get in depth analysis for a solution or workaround.
communities.bentley.com/.../29122.how-to-add-a-lookup-value-for-a-particular-constraint
Comments or Corrections?
Bentley's Product Advantage Group requests that you please confine any comments you have on this Wiki entry to this Comments or Corrections?" section. THANK YOU
