Product(s): | AECOsim Building Designer V8i | ||
Version(s): | 08.11.09.866 | ||
Environment: | N/A | ||
Area: | General | ||
Subarea: | N/A |
When using AccuDraw, I can use key-in. Is there any complete list all the AccuDraw with its description?
Yes, it is available in AECOsim help. Go to Help > AECOsim Building Designer Help > Search tab . In search tab, search using ' Complete List of AccuDraw Shortcut Key-ins' and select 'Search titles only'. It will give you a complete list of all key-ins.
You can also key-in, '$%notepad$(MS_ACCUDRAWKEYS)' to open 'shortcut.txt' file. This file contains all AccuDraw shortcuts.
