Configuring the BOM and Reports-v8i
Product(s):OpenPlant Isometrics Manager
Version(s):08.11.11.XXX (SS6)
Area: Settings/Attributes
Subarea: -
Original Author:Keith Couvillion, Bentley Product Advantage Group
BOM / Report Configuration
The material report on the drawing is controlled with the report definition file (report.def). This definition file provides a very flexible way of specifying the material output on the drawing.
With the report definition file multiple reports can be defined which will always be processed any time a drawing is generated. Not all reports need to be included in the drawing. All reports become available as text files. At the discretion of the user these files can be used for various purposes. They may even be formatted in such a way that they can be used as input into the material handling system of the organization.
Note -With Recent release of OpenPlant Isometrics Manager - Version 08.11.11.224 SS6 Refresh 2, Many things have been changed. Users are advised to take a notice on changes that has been made to facilitate the ease of use for customizing reports.
This can be commonly check for both AutoPLANT Modeler-OpenPlant Isometrics Manager & OpenPlant Modeler-OpenPlant Isometrics Manager
Report Definition
Report Definition File
  1. From the Isometric Configuration dialog:
  2. Select the Isometrics Style tab
  3. Style – Select the relevant style from the dropdown
  4. Select Advanced from the left pane
  5. Click Open Report Definition
    Note: The header of the report definition file explains the available option to configure the content and layout of reports.
Table Definitions
The table layout of a material report is defined by COLUMN keywords. The column definition has the following syntax:
COLUMN = <width> : <format/alignment> : <expression>
COLUMN = 3: R : PARTID
COLUMN = 19: R : QUANTITY
COLUMN = 7: R : SIZE1
COLUMN = 7: R : SIZE2
COLUMN = 2:   :
COLUMN = 60: W : IE_DESCRIPT
Where:
<width>specifies the width of the column in millimeters (Note: This has changed as it used to specify character count for the width)
<format/alignment>can be one of the following:
L – left aligned
C – centered
R – right aligned
W – wrap (a new line will be added if the length of the expression exceeds the width of the column
<expression>is an expression for the content of the report column. Any component attribute or string can be used. Example: IE_DESCRIP + UUID + “and a string” would concatenate the attributes IE_DESCRIPT and UUID and the string “and a string.”
Note: The COLUMN width field is now interpreted as a millimeter (MM) value instead of a character count. User may need to change their reports a bit. This allow user for easier settings. For More information click here>>>>
Displayed Properties
The COLUMN keyword specifies the properties to include and their sequence. In the example below, the PARTID property is the first property in the report, followed by the QUANTITY property. The properties are ordered from left to right in the report.
COLUMN = 2:   :
Table Headers
To specify a fixed text as start of the report, use the TEXT keyword. Extra flexibility is provided with the WRITE keyword. The WRITE keyword writes the variable part of the report in between the fixed text from the TEXT keywords.
Below is an example positioning the material table between a header and a single footer line:
TEXT = @ ----------------------------------------------------------------
TEXT = @  PART | QUANTITY | SIZE1 | SIZE2 |     DESCRIPTION
WRITE =
Bill of Material
Location on Drawing
The position of the Bill of material is defined by the position of its related text node. By default the text node number for the Bill of Material is set to 60. The text node number for the Pipe Cut List is set to number 61. These default numbers can be changed by changing the related property in the Bill of Material definitions file.
Component Types
Use the INCLUDE and EXCLUDE keywords to specify the type of elements that will be included in, or excluded from, the report. The example below includes only field items and excludes welds.
INCLUDE = IE_FIELD=1
EXCLUDE = IE_TYPE=CT_WELD
Field and Erection Materials
To specify a report that only contains field components, specify the following line in the material report: INCLUDE = IE_FIELD=1
REPORT = FLD
# this to include only field items
    COLUMN =  2:   :
    GROUP  = PARTID
    SORT   = PARTID:N
    SEP    = @
    SORTHEADERS = 1
    TEXT = @                       Field Materials
    Write =
END
Grouping / Sorting Reports
The grouping and/or sorting of the report contents is done by adding the GROUP and/or SORT keywords to the report definition. Each field in the column list can be used as grouping or sorting criteria.
GROUP = PARTID
SORT = PARTID:N
Note: Removing the GROUP keyword will create a material list with each component on a separate line.
Summarizing Reports
To summarize the number of components that have been grouped together, use the QUANTITY keyword.
Combining Reports
If you want to have a material list that first shows the shop items and then the field items, you can combine 2 reports into one. The example below combines a report named shp with a report named fld.
# The COMBI report combine the SHP and FLD report into a single report
# and attaches it to textnode 60 in the isometric
REPORT = combi
   WRITE = shp
   TEXT = @
   TEXT = @
   WRITE = fld
   NODE = 60
END
Enable/Disable Reports
The appearance of a report on the drawing can be enabled or disabled. The placement and positioning of a report on the drawing is controlled by tying it to a text node element in the seed file.
Adding or removing the NODE keyword to display or not display the report on the drawing. A ‘#’ can also be used to turn the line into a comment, causing the placement of the report to be disabled.
Placement enabled:
NODE = 60
Placement Disabled:
#NODE = 60
Pipe Cut Length Report
Include the Cut ID in the report
  1. To include the cut id of the pipe cut labels in your pipe cut report, specify the CUTID keyword for one of the columns. The NODE keyword specifies the location of the report in the drawing.
    # The CUT report lists the pipe cut pieces
    # Attaches to text node 61
    REPORT = CUT
        INCLUDE = IE_TYPE=CT_PIPE|CT_BEND
        COLUMN  = 6:C:CUTID
        COLUMN  = 7:R:SIZE1
        COLUMN  = 21:R:QUANTITY
        COLUMN  = 3:R:
        COLUMN  = 80:W:IE_DESCRIPT
        GROUP   = CUTID
        SORT    = CUTID
        NODE    = 61
    END
  2. With use on New setting, Cut list for Reports overflows, click here>>>> for more details
Enable the Placement of Pipe Cut Labels
The User Labels section in the Configuration Manager is used to control the placement of Pipe Cut Labels in the drawing.
  4. Select User Labels from the tree
  5. Select Pipe Cut Labels
Weld Report
Include the Weld reports in BOM
In Default Report.def file a sample reported is listed which user can use it as reference and customize and add more data as per requirement. See below sample Report.
# A sample weld report
REPORT = WELD
include = IE_TYPE = CT_WELD
COLUMN = 5:C:WELDID
COLUMN = 10:R:SIZE
COLUMN = 10::TYPE
# the next two columns list the pipe/fitting connected by the weld.
COLUMN = 30:W:left(EC_CLASS)
COLUMN = 30:W:right(EC_CLASS)
SORT = WELDID:N
SEP = @
END
Example:
User can add report type in existing COMBI report and get the information. See below settings to see in BOM.
  1. Add values & report type in COMBI report.
    REPORT = combi
    WRITE = shp
    TEXT = @
    TEXT = @
    WRITE = fld
    TEXT = @ ---------------------------------------------------------------------------------
    TEXT = @ WELDID | SIZE | TYPE | CONNECTION-1 | CONNECTION-2
    WRITE = WELD
    NODE = 60
    END
  2. Save & close file.
  3. See Image below for Sample report.
    Note - Here left(EC_CLASS) is always pipe as first connection if exists. Second EC_CLASS is second connection element. For more information of these attributes use, click here>>>>
Spools List Report
Include the Spools List reports in BOM
User can add the following report type in report.def file and get the information. See below settings to see in BOM.
  1. Add the following report in report.def
    # A sample Spools report
    REPORT = SPOOLS
      INCLUDE = IE_FIELD=0
     COLUMN   = 100:R: "SPOOL NUMBER  " + PARTID + "  =  " + SPOOL_ID
     GROUP = SPOOL_ID
      SORT = SPOOL_ID:N
      SEP = @
      NODE = 105
    END
  3. Open Isometric Configuration -> Isometric Style -> Advanced  -> Open Seed File
  4. Attach text node at proper place in the seed file
  5. Close the seed file; Generate Isometrics and Verify Result.
Configure BOM Reports
Include MARGIN between the Text in BOM
A margin can be specified between text and the column borders. For instance with a column width of 30 and a margin of 2 only 26 mm will be usable for text. MARGIN can be specified outside a report. In that case every report will be initialized with that margin. When defined in a report the global margin will be overridden.The default value for margin is 1mm.
# A sample report that writes shop material to a report
MARGIN = 3
REPORT = SHP
# this to include only shop material
COLUMN = 2: :
GROUP = PARTID
SORT = PARTID:N
SEP = @
SORTHEADERS = 1
TEXT = @ Shop Materials
Write =
END
See BOM  output shown for both without MARGIN and with MARGIN.
Without MARGIN
With MARGIN
Include SPACING between the Text in BOM
In Default Report.def file a sample reported is listed, which user can use it as reference and customize it as per requirement. See below sample Report.
SPACING = 7
REPORT = SHP
COLUMN = 2: :
GROUP = PARTID
SORT = PARTID:N
SEP = @
SORTHEADERS = 1
Write =
END
Without SPACING value
With SPACING value
Separator (SEP)
The separator is only used when the report is to be output as text. The SEP statement actually forces the report to be output as text. A report is no longer output as a formatted text files.
MAX-LINES
Specifies the maximum number of lines available for the report. In case the report contain more lines the behavior is that the report continues with an offset to the right. In case MAX-LINES isn’t defined or is zero the report can have infinite length. This does implements multi column reports.
Click here>>>> to check more information where this setting can be used. Also check >>>> for other example use of it.
COLUMN
COLUMN =  30: R : SIZE
The COLUMN width field is now interpreted as a millimeter value instead of a character count. User may need to change their reports a bit. It will however make life much, much easier.
Click here >>>> to check problem description article related to this.
OpenPlant Isometrics Manager V8i (SELECTseries6) Version: 08.11.11.224  Refresh 2
Note the above versions are now using Millimeters instead of characters. Applicable to both AutoPLANT Modeler & OpenPlant Modeler
Steps to Resolve
  1. OPEN { report.def }
  2. below is the old out of the box version settings.
  3. The following is altered for standard Out Of the Box Isometrics.
  4. Save file close and re-run the ISO to check results:
    NOTE : End user should open seed file and measure in MILLIMETERS according to their Custom BOM. This setup is specific to individual project basis and different settings may require based on various projects used.
  5. See results:
  6. For details click here>>>>.
User Can also See other wiki articles and its sub articles on configuring various types of reports in OpenPlant Isometrics Manager.
Comments or Corrections?
Bentley's Product Advantage Group requests that you please confine any comments you have on this Wiki entry to this "Comments or Corrections?" section. THANK YOU!
