How to Format Number Property in IsoSheet Name-v8i
Product(s):OpenPlant Isometrics Manager
Version(s):08.11.09.XXX (SS5) | 08.11.11.XXX (SS6)
Area: Settings/Attributes
Subarea: -
Original Author:Rahul Kumar, Bentley Product Advantage Group
In OpenPlant Isometrics Manager, Isometric drawing nomenclature formatting required by user. Please find below explanations and illustrates on changing the format.
In OpenPlant Isometrics Manager, the isometrics output drawing name contains three parameters, LINENUMBER, ISO, and NUMBER. As per the Project requirement users might need to change this to some different formats. Currently, the NUMBER property starts with the format as 1, 2, 3…and so on. The requirement is to get the NUMBER property formatted and to produce the output as 01, 02, 03…etc. Notice the below changes in schema files under the ISO_SHEET class will aid user to achieve this settings. This has been shown in Context with OpenPlant Modeler and OpenPlant Isometrics Manager.
OpenPlant Modeler - OpenPlant Isometrics Manager
  1. In Class Editor, Open "OpenPlant_3D.01.07 schema". See Image below.
    Note -Navigate to working project path as shown below.
    (C:\ProgramData\Bentley\OpenPlantModeler V8i\WorkSpace\Projects\OPModeler_Metric\DataSet\Schemas)
  2. (Optional, select when dialog prompts) Locate a missing reference OpenPlant.01.07 for schema Openplant_3D.01.07. See image below.
    Note - Path to check - (C:\ProgramData\Bentley\OpenPlantModeler V8i\WorkSpace\OPModeler\schemas)
  3. Right click on "OpenPlant_3D.01.07 schema" & click on supplement Schema option.
  4. Using "Add" button, select Supplemental schema "OpenPlant_3D_Supplemental_Modeling.01.07.ecschema" schema and click on "Open". See image below.
  5. Similarly add OpenPlant_3D_Supplemental_Isometrics_Isoextractor.01.07.ecschema. See image below.
  6. (Optional If dialog appears) Click on "Open" for allowing to select Missing reference schema folder. User might need to click on multiple times till it locates all missing reference schema. See image below on how to navigate the correct folder path.
  7. Navigate to ISO_SHEET Class.
  8. Go to Property Tab, and select NAME property.
  9. Check "Calculated ECProperty Specification" custom attribute.
  10. Change the Expression as shown in image below:
    this.LINENUMBER & "-iso-" & System.String.Format("{0:D2}",this.NUMBER*1)
    Note- Do Not use copy command for writing expressions shown above. It might not work for quotes. It is advisable to write the expressions in notepad and copy paste the expression in schema, or directly write it in schema.
  11. Using D2 in expression will give results as 01, 02, 03 etc. With D3, the results will be 001, 002, etc. Also set 'Required ECExpression SymbolSets[0]' to System.String to call for the expression.
  12. this.NUMBER*1, here 1 denotes the numbering process to begin with 1. i.e. 001. with this.NUMBER*3, it will start as 003.
  13. Save & Close Schema.
  14. Launch OpenPlant Modeler & select project say OPModeler_Metric here.
  15. In OpenPlant Modeler re-create iso sheet and publish I model. User can also See modified name in IsoSheet Manager.
  16. Publish an i-model.
  17. Launch OpenPlant Isometrics Manager. Generate Isometrics and verify results. See image below.
communities.bentley.com/.../12636.setting-file-type-dgn-or-dwg-and-paper-setting
Comments or Corrections?
