To Modify Date Format & Style in OIM-v8i
Product(s):OpenPlant Isometrics Manager
Version(s):08.11.09.XXX/08.11.11.87
Environment:Windows 7 (64 bit) & others
Area:Settings/Attributes
Subarea:-
Original Author:Rahul Kumar, Bentley Product advantage Group
In OpenPlant Isometrics Manager, to display DATE with different format
Problem Description
In OpenPlant Isometrics Manager, DATE format required to change. In several conditions & various regional settings, date formats are different. User wants to change the format as desired. See current format.
Below steps will aid user to format date & its styles. Below settings can be experienced using Both AutoPLANT Modeler & OpenPlant Modeler along with OpenPlant Isometrics Manager
Steps to Resolve
  1. Launch "Isometric Configuration" dialog.
  2. From "Advanced" Node click on "Explore Style" option. See image below.
    Note - User can also navigate to project path and open the file. See default path shown for reference
    %Project Root%\Plant V8i\Bentley Plant V8i Projects\SAMPLE_METRIC\Config\OpenPlant\Isometrics\styles\IFC\config
  3. Go to Config folder and open "textnodes.txt" file.
  4. Check DATE format mentioned in file.
    # The DATE funtion has the format
    # DATE (<date style>, <date format>)
    # <date style> 0 - US style (month, day, year)
    # 1 - European style (day, month, year)
    # <date format> examples shown for US style (January 2 2014)
    # 0 - 1-2-14
    # 1 - 01-02-14
    # 2 - 1-2-2014
    # 3 - 01-02-2014
    # 4 - 1/2/14
    # 5 - 01/02/14
    # 6 - 1/2/2014
    # 7 - 01/02/2014
    # 8 - 20140102
  5. Based on above format, type DATE = DATE (0,7)
    Note -
    Please be careful regarding spaces between variables mentioned above, as results may vary using different format.
  6. Save & Close file.
  7. Generate Isometrics & Verify result. See image below with selected date format 7.
  8. Similarly user can select any style & format as per requirement.
Still a Problem?
If above problem still persist, then please create a Service Request and contact the Bentley Product Advantage group.  Please include a list of all relevant details to get in depth analysis for a solution or workaround.
communities.bentley.com/.../12636.setting-file-type-dgn-or-dwg-and-paper-setting
Comments or Corrections?
