| Version(s): | 10.01.00.136 | ||
| Area: | Platform Tools | ||
| Subarea: | N\A |
File specific issue where Dimensioning in V8i SS6 is correct using the 1/8" Text Style listed in the dgn. but when the same file is opened in CONNECT EDITION it either crashes or the scale becomes so large that it is not in proportion to the drawing.
The Font in the Text Styles dialog was set to Working Font, but it also had the TT icon in front of it as True Type Font. There is no TT font for Working, but after clicking on the selection for Bentley Working Font 1, Saved it and then the dimension places properly.
