| Version(s): | 08.11.09.866 | ||
| Area: | Annotation | ||
| Subarea: | Text |
When I am trying to do a Find/Replace Text operation, the following .NET Framework error appears:
Please see that your settings are the same or similar to the following image in Control Panel > Add/Remove Programs > Turn Windows Features on or off. All .NET versions are required to be available (checked):
