| Version(s): | 10.02.00.35 | ||
| Area: | Platform Tools | ||
| Subarea: |
| Subarea: |
I want to open SKP files in AECOsim Building Designer in AECOsim CONNECT Edition Update 2. How can I do it? When I open the file it is blank.
Importing, exporting, and referencing SketchUp Models (.skp files) is supported. You can use the standard Open dialog to access SketchUp files in read-only mode. You can import and export SketchUp 2015, 2016, or 2017 files in AECOsim CONNECT Edition Update 2.
