| Product(s): | OpenPlant Isometrics Manager |
| Version(s): |
08.11.09.XXX (SS5) | 08.11.11.XX (SS6) |
| Environment: | Windows 7/8.1/10 (64-bit) |
| Area: | Configuring the BOM and Reports |
| Subarea: | |
| Original Author: | Abhilash Panchal, Bentley Product Advantage Group |
In OpenPlant Isometrics Manager,User is looking for some Customization in Isometric BOM where Bolt size value should come as Inherited Pipe size.For e.g. If Pipeline size is 200 mm (Metric Project), Bolt size column should come as 200 instead ¾” or some fraction value.
Now add below EC expression in Calculated EC property Specification.
ECExpression:
this.GetRelatedInstance("JOINT_HAS_FASTENER:1:JOINT").GetRelatedInstance("PORT_HAS_JOINT:1:PORT").GetRelatedInstance("PIPING_COMPONENT_HAS_PORT:1:PIPING_COMPONENT").NOMINAL_DIAMETER
Value this.Size1
REPORT = BOLT
# this to include only shop material
INCLUDE = IE_TYPE=CT_BOLT
COLUMN = 3: R : PARTID
COLUMN = 19: R : QUANTITY
COLUMN = 12: R : SIZE_BOLT
COLUMN = 14: :
COLUMN = 60: W : IE_DESCRIPT
GROUP = PARTID
SORT = PARTID:N
END
communities.bentley.com/.../how-to-add-desired-custom-property-value-to-openplant-isometrics-bom
