How to Show Calculated Pipe Weight in BOM-v8i
Product(s):OpenPlant Isometrics Manager
Version(s):08.11.09.XXX (SS5) | 08.11.11.XXX (SS6)
Area: BOM
Subarea: -
Original Author:Deepak Singh, Bentley Product Advantage Group
In OpenPlant Isometrics Manager, user wants to show calculated pipe weight in bill of material.
DRY_WEIGHT represent the weight of pipe. In bill of material weight of pipe should show correctly as per the total length of pipe. This wiki article explains how to show calculated weight of pipe in bill of material.
OpenPlant Modeler-OpenPlant Isometrics Manager
  1. Open OpenPlant_3D.01.07. ecschema using Bentley Class Editor.
  2. Supplement it with below highlighted schema.
     For More information on supplementing schema click here>>>>
  3. Navigate to Plant Base Object, right click & select Custom Attribute > Copy to copy Default Bill of Materials Label custom attribute as shown below.
  4. Navigate to PIPE Class, right click and select paste to paste the copied custom attribute as shown below.
  5. Under Default Bill of Materials Labels Custom attribute, right click on Other Attribute & select Add element to add an attribute as shown.
  6. Enter the details as shown below.
    Value: System.Math.Round((this.LENGTH_EFFECTIVE * this.WEIGHT),2)
  7. Save the settings & verify the result as shown.
communities.bentley.com/.../12642.configuring-the-bom-and-reports
Still a Problem?
If above problem still persist, then please create a Service Request and contact the Bentley Product Advantage group.  Please include a list of all relevant details to get in depth analysis for a solution or workaround.
Comments or Corrections?
