| Product(s): | AECOsim Building Designer |
| Version(s): | 08.11.09.866 | |
| Environment: | N\A | |
| Area: | Print/Plot | |
| Subarea: | N\A |
Grid bubbles display in my view but will not print. Also they do not display in the Preview window in the Print Dialog.
In Select Series 6, the Level S-GRID-MASK for whatever reason is covering up the Elevation Target cell. When it is covered up by this level, it will not print.
To get these cells to print
- go into Level Manager and set the Priority of the S-GRID-MASK level to -100 so that the mask is behind the Elevation Target cell.
- In Level Manager, right-click on the level named S-GRID-MASK and right-click and select Properties with a left mouse click. Please note that any graphic elements that intersect the Elevation Target will no longer be masked out but this should be rare.
- Or you can create a Pen Table - communities.bentley.com/.../NoMask.tbl. You can edit the Printer Driver Configuration file (.pltcfg) and specify the Pen Table name so that it will always be run with the printer driver.
- Or by using a Print Style - this method is a little more complicated but it can be created as a Default Print Style that would be honored regardless which printer driver you use.
