| Version(s): | 10.02.00.35 | ||
| Area: | Drawing Views | ||
| Subarea: | Callouts |
After adding a step to an existing Plan Callout, I noticed that the grid already displayed in the Drawing Model or when applied to the 3D Model suddenly stops at the point where I added that step. Is there any way to display the full grid while keeping the step?
Defect 810554 has been filed against this issue. As you have found, the grid's display is truncated at the point where the first step is added, but only when the Clip Volume's edit handle on the stepped side is cropped.
Two potential interim workarounds would include:
1. Manually referencing grid Models to the Drawing Model.
2. Un-crop the applicable edit handle.
