| Product(s): | AECOsim Building Designer V8i | ||
| Version(s): | 08.11.09.376 and above | ||
| Area: | Installation | ||
| Subarea: |
When installing AECOsim Building Designer (ABD) the following options need to be used.
More details about UAC and ABD can be found in the product ReadMe.
For CONNECT Edition products this is accessible prior to installation from the Bentley Product Documentation website. Click on the Building Design tile; select AECOsim Building Designer Readme and the version you need, then click on the green tile background to proceed to the document:
