| Product(s): | OpenPlant Isometrics Manager |
| Version(s): | 08.11.11.224 (SS6) |
| Environment: | Windows 7/8.1/10 (64 bit) |
| Area: | Settings/Attributes |
| Subarea: | |
| Original Author: | Rahul Kumar, Bentley Product Advantage Group |
To Check Fixing BOM column Text Wrapping issue.
With latest release of OpenPlant Isometrics Manager, it has been found that BOM column text started wrapping. This is mainly due to the width of the column assigned to report.def file. In previous version width of the column signifies character positions, whereas in SS6 refresh 2, width of the column represents the length in millimeters (MM). Below are the steps to resolve such issue when using older project report.def file format with latest version of OpenPlant Isometrics Manager.
If above problem still persist, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
communities.bentley.com/.../12642.configuring-the-bom-and-reports
