| Version(s): | 08.11.09.831 | ||
| Area: | Configuration | ||
| Subarea: | DataGroup System |
How to add new glass material (property instance) for doors ?
There are two ways to do it -
1) We can make the required property instance changes in EnumLookups_Architectural.xml by adding new property instance for vision panel doors. The aforementioned file can be found in the following path :
C:\ProgramData\Bentley\AECOsimBuildingDesigner V8i Ss\WorkSpace\BuildingDatasets\Dataset_XX\datagroupsystem [similar for CONNECT]
2) Please refer the attached video [CONNECT Edition] to see how new property instance can be added and set to default -
