| Product(s): | OpenPlant Isometrics Manager |
| Version(s): | 08.11.09.XXX (SS5) | 08.11.11.XXX (SS6) |
| Environment: | Windows 7/8.1/10( 64 bit) |
| Area: | Settings/Attributes |
| Subarea: | Configuring the BOM and Reports |
| Original Author: | Kestutis Mitkus, Bentley Product Advantage Group |
All components classes has their own Item Code value in ecschema, by which component's PARTID numbers are assigned. Some components are very identical and because of this Item Code value, they are grouped together. This value can be edited by adding additional Properties or Attributes, by which components will be assigned with different PARTID numbers.
In this example user had a requirement to list all OWNER Group Weld Neck Flanges separately.
To assign different PARTID's for the identical Flanges, we need to have a Property, which differs them. All Items in AutoPLANT has unique COMP_ID property, which can be used for WELD_NECK_FLANGE PARTID assignment.
COMP_ID in ecshema is mapped with GUID property.
communities.bentley.com/.../12642.configuring-the-bom-and-reports
communities.bentley.com/.../30479.how-to-generate-reports-based-on-size
