How to create Mitred joint between steel beam members?
 Version(s):10.02.00.35
 Environment:N/A
 Area:Structural Design
 Subarea:Steel Beams
Problem Description
Steps to Resolve
A mitred joint can be created between two Structural steel sections.
Go to Modify>Connect Walls>Select ‘Connect Forms as L’. Then select the two beams to convert the joint.
