How to Show Bolt Weight in Bill of Material
Product(s):OpenPlant Isometrics Manager
Version(s):
8.11.11.87/96 (SS6) & above
Environment: Windows 7 (64-bit) | Windows 10
Area: Settings/Attributes
Subarea: Customization
Original Author:Deepak Singh, Bentley Product advantage Group
In OpenPlant Isometric Manager, to show bolt weight in Bill of Material.
Using AutoPLANT Modeler & OpenPlant Isometrics Manager, to show Bolt Weight in Generated Bill of Material.
  1. Launch Bentley Class Editor.
  2. From Bentley Class Editor Interface, click on Open.
  3. Open OpenPlant_3D.01.07. ecschema of your particular project, say here metric project
    C:\ProgramData\Bentley\PlantV8i\BentleyPlantV8iProjects\SAMPLE_METRIC\Config\OpenPlant\schemas
  4. Right Mouse on OpenPlant_3D schema and from drop-down menu select Supplement Schema.
  5. In window of Specify Supplemental Schema, select Add.
  6. Select OpenPlant_3D_Supplemental_Isometrics_Isoextractor.01.07. ecschema and hit Open.
    Folder Location
  7. Click on OK
  8. Expand Classes, navigate to BOLT class, switch to Properties Tab, search property name DRY_WEIGHT.
  9. Click on override, to localize the property.
  10. Right Mouse on DRY_WEIGHT property, from cascading menu select Custom Attributes > Add/Remove to add custom attributes.
  11. Select the below highlighted custom attributes, using drop Arrow icon, add the custom attributes as shown below.
  12. Set the location to OpenPlant_3D.01.07 as shown.
  13. Select OK.
  14. Under AutoPlant_PDW_Catalog_Property_Map & AutoPLANT_PDW_Property_Map custom attribute section.
  15. Add PropertyName as WEIGHT_DRY as shown.
  16. Save the settings.
  17. Open Report definition file of your specific project & style folder.
  18. Use Project Administrator or File Explorer to edit the report.def file.
    File Directory:
    C:\ProgramData\Bentley\Plant V8i\Bentley Plant V8i Projects\SAMPLE_METRIC\Config\OpenPlant\Isometrics\styles\IFC\config
    Using Project Administrator.
    Click on Create/Modify.
    Choose your particular style and Click on Advanced Option. Select Open Report Definition.
  19. Scroll Down and under FLD report make changes as shown.
    EXCLUDE = IE_TYPE=CT_WELD|CT_BOLT
  20. Below FLD report write a new report definition for BOLT as shown.
    Accumulated Weight
    REPORT = BOLT
    # this to include only field items
    INCLUDE = IE_TYPE=CT_BOLT
    COLUMN =  3: R : PARTID
    COLUMN = 19: R : QUANTITY
    COLUMN =  7: R :
    COLUMN =  7: R :
    COLUMN = 10: A2R : DRY_WEIGHT
    COLUMN = 2: L  : "kg"
    COLUMN =  2:   :
    COLUMN = 60: W : IE_DESCRIPT
    GROUP    = PARTID
    SORT       = PARTID:N
    SEP          = @
    SORTHEADERS = 1
    Write =
    END
    In above report definition SIZE1 & SIZE2 of bolts are hidden. Accumulated weight for Bolt are written along with weight unit as “Kg” at a precision of two digit decimal values.
    Under COMBI report modify changes as shown
    WRITE = BOLT
    Modeling Arrangement
    Results in OpenPlant Isometrics Manager.
    Individual Bolt Weight
    For individual Bolt Weight, modify report definition as shown below
    REPORT = BOLT
    COLUMN =  7: R :
    COLUMN =  7: R :
    COLUMN = 10: 2R : DRY_WEIGHT
    COLUMN =  2:   :
    GROUP    = PARTID
    SORT       = PARTID:N
    SEP          = @
    SORTHEADERS = 1
    Write =
    END
  21. Under Combi report
    WRITE = BOLT
    Result in OpenPlant Isometric Manager
communities.bentley.com/.../31120.how-to-hide-sizes-of-bolts-in-bill-of-material
Applies To Product(s): OpenPlant Modeler Version(s): 8.11.11.87/96 (SS6) & above Environment: Windows 7 (64-bit) | Windows 10 Area: OpenPlant Modeler Specification Generator Subarea: Data Original...
Comments & Corrections?
