To Get Shop Field Information for welds in OpenPlant Isometrics Manager-v8i
Product(s):OpenPlant Isometrics Manager
Version(s):08.11.11.XXX
Environment:Windows 7/8.1/10 64 bit
Area: Settings/Attributes
Subarea: Configuring the BOM and Reports
Original Author: Bentley Technical Support Group
To Get Shop Field information for welds in OpenPlant Isometrics Manager.
In OpenPlant Isometrics Manager, there was requirement to get Shop, Field or other weld details under weld Reports. User need to assign it first in Model and based on that it can be produced inside the OpenPlant Isometrics Manager. Below steps has been described in context with OpenPlant Modeler and OpenPlant Isometrics Manager. However similar approach can be used in context with AutoPLANT Modeler and OpenPlant Isometrics Manager.
  1. Launch OpenPlant Modeler, Select Project Unit.
  2. Place a Pipe and Fittings. Zoom in Weld generated.
  3. Right click on weld and select Modify “Component” option.
  4. From “Operating Conditions” tab, select “Type” as “Field”.
  5. Similarly set other weld type as per requirement say “Shop”, “Field”, “FieldFit” & others like shown in below image.
  6. Create Isosheet and publish I dgn to generate isometrics.
  7. Launch OpenPlant Isometrics Manager.
  8. Open “Isometrics Configuration” dialog.
  9. From Advanced option, click on “Open Report Definition” option.
  10. Add “TYPE” attribute to weld report. See one sample mentioned below.
  11. Generate Isometrics and verify results.
communities.bentley.com/.../19833.how-to-add-weld-tag-as-fwffw-on-isometrics-weld-in-openplant-isometrics-manager
Comments or Corrections?
Bentley's Technical Support Group requests that you please confine any comments you have on this Wiki entry to this Comments or Corrections?" section. THANK YOU!
