Modifying the Welding Information-v8i
 Product(s):OpenPlant Isometrics Manager
 Version(s):08.11.11.XXX
 Area: Settings/Attributes
 Subarea: Configuring the BOM and Reports
 Original Author:Keith Couvillion, Bentley Product Advantage Group
Welding
Weld Summary Report
A weld summary report can be created by adding the CT_WELD component type to the INCLUDE keyword in the report as follows:
INCLUDE = IE_TYPE=CT_WELD
COLUMN = 6:C:WELDID
In order to display the weld report on the drawing, it must be tied to a text node with the NODE keyword.
Include Weld ID in the Report
To include the weld id of the weld labels in your weld summary report, specify the WELDID keyword for one of the columns. The NODE keyword specifies the location of the report in the drawing.
EXCLUDE = IE_FIELD=0
COLUMN = 6:C:WELDID
Dimensioning of Field Welds
Dimensions always stop at field welds, which ensure cut lengths are properly defined. No user configuration available.
Field Fit Welds
 To check on adding Field Fit Weld length, Click here> > > for reference. Also check See Also Section for link.
Weld Labels
The User Labels section in the Configuration Manager is used to control the placement of Weld Labels in the drawing.
Open the Isometrics Configuration tool
From the Isometric Configuration dialog:
  1. Select the Isometrics Style tab.
  2. Style – Select the relevant style from the drop down.
  3. Select User Labels from the tree.
  4. Select Weld Labels.
  5. Generate Isometrics & Verify Results. See image below.
  6. Also User have an option to remove the weld ID by checking "OFF" the specific labels. See image below.
  7. Generate Isometrics & verify results. See image below.
communities.bentley.com/.../24621.how-to-assign-fieldfit-weld-allowances-or-other-weld-types-for-bom-cut-list-in-openplant-isometrics-manager
communities.bentley.com/.../12642.configuring-the-bom-and-reports
Comments or Corrections?
