| Version(s): | 08.11.09.866 | ||
| Area: | Modify | ||
| Subarea: | N\A |
We are planning to move from MicroStation into AECOsim Building Designer. Is there the possibiliy to Import or to convert MicroStation 3D elements into AECOSim Building Designer data?
| Original Author: | XXXXAuthorXXXX |
