| Version(s): | V8i and CONNECT Edition | ||
| Area: | Annotation | ||
| Subarea: | DataGroup Annotation |
When trying to annotate a diffuser an error pops up "ERROR!!! Unable to find active cell." Even if DataGrooup Annotation Cell is attached the same issue happens.
This might be because there is no annotation cell defined for annotating the grilles. The following video shows how you can create one for a particular grille type:
