| Product(s): | OpenPlant Isometrics Manager |
| Version(s): | 08.11.11.285 (SS6Refresh4) |
| Environment: | Windows 7/8.1/10 (64-bit) |
| Area: | Settings/Attributes |
| Subarea: | Modifying BOM |
| Original Author: | Swapnil Joshi, Bentley Product Advantage Group |
To exclude components with a specific SORT CODE from BOM
The user has assigned a specific SORT CODE to different components which he wants to exclude from the Bill of Materials (BOM). By following the steps mentioned below the user will be able to achieve this requirement. Only OpenPlant Isometrics Manager 08.11.11.285 is the supported version.
communities.bentley.com/.../modifying-bom-for-autoplant---openplant-isometrics
communities.bentley.com/.../configuring-the-bom-and-reports
If the above problem still persist, then please create a Service Request and contact the Bentley Product Advantage Group. Please include a list of all the relevant details to get in depth analysis for a solution or a workaround.
Bentley's Product Advantage Group requests that you please confine any comments you have on this wiki entry to this "Comments or Corrections?" section. THANK YOU!
