Applies To | |
Product(s): | OpenPlant Isometrics Manager |
Version(s): | 08.11.11.XXX |
Environment: | Windows 7/8.1/10 (64-bit) |
Area: | Settings/Attributes |
Subarea: | Modifying BOM |
Original Author: | Swapnil Joshi, Bentley Product Advantage Group |
To set component to shop or fieldĀ in BOM depending upon the value in AutoPLANT Modeler.
OpenPlant Isometrics Manager does not identify whether the component is set to shop or field in AutoPLANT Modeler. Hence making some schema changes will help it identify whether the component is set to shop or field in AutoPLANT and help it place accordingly in the BOM in OpenPlant Isometrics Manager.
communities.bentley.com/.../configuring-the-bom-and-reports
