| Product(s): | OpenPlant Isometrics Manager |
| Version(s): | 08.11.09.440 & Above |
| Environment: | Windows 7 (64 bit) |
| Area: | Settings/Attributes |
| Subarea: | |
| Original Author: | Rahul Kumar, Bentley Product Advantage Group |
In OpenPlant Isometrics Manager, during isometrics generation it displays message as “Isometric successfully, but PCF generation failed”.
OpenPlant Isometrics Manager, when isometrics get generated, sometimes it display a message as “Isometric generated successfully, but PCF generation failed”. This happens mainly because of incorrect mapping of End Preparations or absence of certain end preps which have been used inside the drawings. Also check below production log.
------ Convert L00 to PCF
- input file: C:\ProgramData\Bentley\Plant V8i\Bentley Plant V8i Projects\SAMPLE_METRIC\Isometrics\Styles\IFC\L00\ISO-L100.r004.l00
- configuration file = C:\PROGRA~3\Bentley\PLANTV~1\BENTLE~1\SAMPLE~2\Config\OPENPL~1\ISOMET~1\Styles\IFC\config\ pcf.ini
no mapping found for OPIM endprep: BW
- symbol not mapped: 90BW (cp=2 ip=1 cm= BW BW)
- symbol not mapped: FLNWNF (cp=2 ip=0 cm= FL BW)
- FAIL
Below steps will aid user to avoid such errors. Below example and error caused shown here using AutoPLANT Modeler and OpenPlant Isometrics Manager. However similar instances might occur using OpenPlant Modeler and OpenPlant Isometrics Manager.
The above errors mentioned due to missing end prep mapping of OPIM & ISOGEN. User need to ensure the isogen end prep used in project and further check it back with OPIM end prep.
If above problem still persist, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
