| Product(s): | OpenPlant Isometrics Manager |
| Version(s): | 08.11.11.224 (SS6) |
| Environment: | Windows 7/8.1/10 (64 bit) & others |
| Area: | Settings/Attributes |
| Subarea: | Modifying Symbols |
| Original Author | Swapnil Joshi, Bentley Product Advantage Group |
To represent the flex hose in OpenPlant Isometrics Manager.
In OpenPlant Isometrics Manager the user wants to change the symbol of the flex hose from the existing symbol. This problem usually occurs in older version of schemas.
communities.bentley.com/.../edit
Comments or Corrections?
