How to show area and volume in the schedule after attaching instance data to MicroStation element
 Product(s):Aecosim Building Designer (Connect)
 Version(s):10.01.00.36
 Environment: N/A
 Area: Import/Export
 Subarea: DataGroup Schedule
When we attach DataGroup instance data to a MicroStation solid or surface, the values for the Volume and Area properties are represented as a zero quantity in the DataGroup schedule.
The key to adding these two values to any schedule would be to include two specifically named properties in the object schema:
1) A property with the name of “SurfaceArea” with an “Area Units” data type to report on the modeled objects Surface Area
2) A property with the name of “NetVolume” with a “Volume Units” data type to report on the modeled objects Net Volume, if available (not available on surface models)
