How To Remove BOM Text Wrapping Issue in Generated Isometrics
Product(s):OpenPlant Isometrics Manager
Version(s):08.11.11.224 (SS6)
Environment:Windows 7/8.1/10 (64-bit)
Area:Settings/Attributes
Subarea:Modifying BOM
Original Author:Swapnil Joshi, Bentley Product Advantage Group
The user is facing a problem in which when he edits the BOM text, he gets the all the text aligned towards left as shown in the image below. On following the below mentioned steps the user will be able to edit the BOM text without hampering the justification.
Steps to Resolve
  1. Open Project Administrator, in the project, expand the OpenPlant Isometrics Manager node and select the settings option to launch Isometric Configuration dialog.
  2. From the Isometric Configuration dialog, open seed file.
  3. In seed file, open View Attributes and enable the text nodes.
  4. Select text node 60 and delete it.
  5. Select key-in browser and type NN=60 to start the node counter from 60.
  6. Select the Place text node from text tasks and place at the same position as the previous text node.
  7. Generate isometrics and verify results.
  8. Double click on the BOM text and confirm that improper text wrapping issue does not persist. See image below.
communities.bentley.com/.../to-fix-bom-column-text-wrapping-issue-in-openplant-isometrics-manager
Still a problem?
if above problem still persist, then please create a Service Request and contact the Bentley Product Advantage Group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
Comments or Corrections?
Bentley's Product Advantage Group requests that you please confine any comments you have on this Wiki entry to this Comments and Corrections?" section. THANK YOU!
