| Version(s): | 10.03.00.40/08.11.28.23 | ||
| Area: | Architectural Design | ||
| Subarea: | Drawing Views |
How do I achieve both transparency and a pattern cell. If I assign a transparent material then the cell becomes transparent too which is not what I want ?
The video below provides the exact workflow on how to achieve this :
