| Product(s): | OpenPlant Isometrics Manager |
| Version(s): | 08.11.09.XXX (SS5) | 08.11.11.103 (SS6) |
| Environment: | Windows 7/8.1/10 (64 bit) |
| Area: | Settings/Attributes |
| Subarea: | |
| Original Author: | Abhijit Bute, Bentley Product Advantage Group |
As desired by few users to open generated isometric dwg in AutoCAD instead of OpenPlant Isometrics Manager, some modification is required in IsoExtractor.bat file. User should be able to get it with limited functionality. Below are the case discussed to achieve the desired settings.
Note - To extract in dwg format and opening the iso with ACAD will drop the component attributes. So you will be unable to read spec data from the components in the graphic environment.
