| | Product(s): | AECOsim Building Designer | |
| | Version(s): | CONNECT Edition | |
| | Environment: | N\A | |
| | Area: | Platform Tools | |
| | Subarea: | Cell Library | |
Problem Description
Unable to find the Cell Library Dialog Box in AECOsim CONNECT Edition.
Cell Library Dialog can be accessed in CONNECT Edition from the following:
- Ribbon: dialog launcher
- Ribbon: split button
- Ribbon:
- Explorer dialog: Click the Manage option from the reset pop-up menu of Parametric Cell Definition under the File tab.
- Toolbox: Primary Tools
- Default Function key menu: <Ctrl+F8>
| | Original Author: | Tathagata Saha | |
