| Product(s): | OpenPlant Isometrics Manager |
| Version(s): | 08.11.09.470 & above |
| Environment: | Windows 7 (64 bit) |
| Area: | Settings/Attributes |
| Subarea: | - |
| Original Author: | Abhijit Bute, Bentley Promotion Advantage Group |
DWG line styles are a subset of MicroStation line styles. Because of this disparity, there are a number of features in MicroStation line styles that do not translate directly to DWG. Below steps help you to map OpenPlant Isometrics Manager isometric DGN line style to his matching dwg line style.
Edit OPIM.csv file
